Having some problems with my Ferroli domicondens he26c
Theboiler keeps tripping out and fault A 02 flashes up with and boiler will not fire up for hot water or heating. Have to reset the boiler and it works for about 5 minutes.
I have watched what happens, boiler fires up. Works for about 5 minutes then goes to a code D2 then fails to reignite.
It's on Eco mode and does not matter if it on programmed timer or override it still trips out.
I have had this problem before and by putting the system on to Eco mode sort of resolved the issue. It would still trip out bit not as often. I have noticed The problems occur following a power cut. Would that cause the system to play up?
Any suggestions would be greatly
