Hello all,
I have a Hawk II that was in the property when we bought it. over the years usually when the weather gets colder, but not always, the hot water starts playing up. The boiler will fire up on hot water demand run for between 10-30 sec the water will get warm but then the boiler will shut down and the water will run cold. After a few more seconds the boiler will fire up again and the water will get warm but again after 10-30 sec it will shut down.
The CH seems to be fine radiators get to the required temp and give out plenty of heat.
I have managed to fix the problem before by replacing the thermistor/flow sensor (sorry not sure which it is) on the HW feed, this works for about 6-8 months and the problem will re-occur.
I have tried the same this time but it hasn't fixed the problem which has got me thinking that it might not be down to this sensor. Also why would so many sensors go faulty? I've currently replaced 3.
Any ideas would be greatly recieved thanks.
