I got a Ferroli Maxima 35C installed during the summer when our house was renovated. We've had a lot of problems with maintaining water pressure (old + new system joined together) which has now been fixed by an excellent plumber who found all the leaks (took 3 months and 3 plumbers).
During this process Ferroli were called in to check the boiler. Since the engineer came round the maximum temperature for hot water has been 50C - even if I set the front panel knob to 65C.
The central heating water temperature works fine up to the maximum 85C temperature.
I assume the engineer has changed an engineer setting using the "M" key but I can't find any documentation anywhere to help me undo this change. Does anyone know (a) if this setting exists and (b) how I reset it? It's taking ages to run a not particularly hot bath!
Many thanks,
Mark
Many thanks,
Mark
