Hi
The DHW on my Ferroli 102 does not work independently of the CH.
The LED does not light and no ho water is pruduced at any temperature.
Hot water is produced, however, if I start up the CH via override or if the CH happens to be on anyway.
Once the CH is truned off, then my DHW stops again as well.
I have tried giving the sensor a basic clean and also the green and yellow wired connector at the rear of the copper wiring block by the fan (an engineer showed me this a couple of years ago as I had intermittent hot water problems back then and this solved it, as it did last year, as it was just dust build up). This year, alas, my little fix is not working and it isnt even an intermittent problem anymore!
I can cope for now by using override to fire the CH is I need hot water but this is really only a short term solution so any advice would be greatly appreciated!
Many thanks in advance.
Regards
Phil
Regards
Phil
