ferroli modena 80 e only firing up for 10 sec
6 Jan 2008
Lanarkshire
had it 6 years not firing up when demand for heating or hot water but does come on for intervals of 10 sec every 5 mins or so the burner light trys to come on but just a flicker it happened before christmas but seemed to rectify itself can you help thanks. bled rads,took air out pump cleaned inside,checked connections etc pressure ok
do fan and pump run when there is a demand?
I believe if you dont know what it is you can hardly be competant to fix it so my next advice would be to call a boiler repair man..
mick if your still on the dhw inlet was sweating gave it tighten that seemed tohave solved the problem thanks
