Hello all,
I have a Ferroli Modena 80 E Boiler that was fitted 13 years ago (approx). The boiler on the whole is still running well.
Last week I noticed that I have a slow pressure drop of around 0.5 bar over about a 9 hour period although I have noticed that the system pressure is not dropping any lower than about 0.9 bar.
From that I’m assuming that the leak I have is balancing out at about this pressure, 0.9 bar (although there may still be a sweat leak somewhere in the system).
I have bled the system and checked all the radiators and pipework that is above the floor level but can find no leak. So it looks as though my leak is below floor level.
My question comes in 2 parts;
• Would the use of Fernox F4 have a chance on sealing this leak (or is there a better sealer)? I know a repair of the leak is the best way to go but lifting laminate flooring at this time is not an option for me.
Whilst charging the stem to pressure the other day I inadvertently left the filling valve slightly cracked open which over pressurized the system then causing the safety valve to open to reduce the system pressure. There is now a very slow drip coming from this valve, mainly when the system is operating.
• Will I need to replace this? Will it gradually stop dripping? Can it be re-sealed?
Thanks in advance,
John
Thanks in advance,
John
