after bolier has been working for a while, seems to power reset itself
ie goes through power cycle when you push the power on button.
any ideas or suggestion on where I should start to look
cheers
started with intermittent hot water and heating, but every time I check the boiler it works for a while the does a power reset all by itself ie
like turning it off then on
