I have a Ferroli HE-260-C Boiler. 2 days ago (immediately after changing the CH settings) the boiler started showing fault F05 ("Fume pressure switch fault and/or Fan fault").
I had a Gas Safe Engineer out who looked at the probable causes, at which point fault A02 flashed up ("Flame present signal with burner off").
The fault now showing is A16 ("Gas valve Fault").
Surely everything on this 3year old boiler isnt failing at the same time?? My question is does this sound likely that the PCB is fried, and so throwing up all sorts of fault codes? I know ferrolis have a particularly bad reputation, but surely its just the one fault (ie PCB) rather than every part at the same time??
Thanks for your help!
