Hi, Thanks in advance for any help or advice.
I am looking to build an extension to the rear of the property, as it is not a detached house I gather the maximum is 3m outwards from the house?
But I was just wondering if anybody could answer my other questions.
Looking to put a plastic roof on it, so I gather its considered a temporary structure (like a conservatory, so it doesn't need a building notice)
But I want to where possible build it still as an extension to building regulations, so, how deep would I be required to dig the footings around the outside?
and, at present there is an outside drain from the kitchen in the way, would this have to be moved? if I move it to the front of the extension, then I will need an inspection pit where it T's into the drainage and will have to notify to building control this alteration?
or would I be better off just notifying the whole lot to building control as a permanent extension and posting a building notice?
reason for wanting to build to building regs is because we want a cavity wall, and seeming foundations have to be dug out anyway, may as well do everything to regulations.
