Had some builders in yesterday returning to fix a small leak on a basement radiator (old pipe connected to new pipe at radiator). After changing the old pipe for a new one they tested all the radiators and said they were working (hot).
The layout is :-
basement 2 rads bathroom and shower
ground 3 rads and boiler
1st floor 3 rads
2nd floor 1 rad and small bathroom (sink/shower)
After I returned, I noticed however that the 2nd floor rad was not working and the shower wasn't running correctly (cold with low pressure on hot).
I bled the 2nd floor rad but it was already full of cold water.
Turning all the rads off below the 2nd floor got the flow going again and the shower was working again. Since I've turned the other rads back on the 2nd floor rad is fine but I'm still having problems getting the shower to kick in (low pressure and cold on every setting except heat on max).
Currently all the rads are fully open. Does this matter or should I have different settings coming away from the boiler?
The boiler has a red dial set at 1.5bar with a max. centr. heating pressure of 2.5 bar. Should the black marker be at around 1.5bar with the heating off or on?
Secondly, I have an old Vaillant boiler (was already in house in 1997) and it doesn't kick in when running hot water anymore and therefore hot taps are cold. It used to be a bit intermittent, one day working, one day not, now it just doesn't work and to get hot water we have to put the heating on. Any clues what that prob is? An easy fix?
Any help gratefully received
The layout is :-
1st floor 3 rads
