The plate heat exchanger in my Turbomax (242/2-5) is scaled up from hard water, and I intend to take it out this weekend to clean it.
Three connections on it are spring clips with O rings underneath, and the fourth is a nut with a fibre washer underneath it. Should I change these seals as a matter of course, or only if they are damaged?
If the cleaning doesn't go well, and I have to replace the HEX, is it OK to buy a new one from somewhere like Ebay? They are half the price of most parts companies. Are they likely to be non-Vaillant parts? Or should I stick to a genuine Vaillant heat exchanger?
Many thanks
Many thanks
