Firstly, I have an electric shower that requires wiring up. Its 9.5kw and the cable is about a 20 meter run going through some trunking and the loft, which has insulation. Can some one explain to me what size of cable is required as i dont exactly know how to use the correction factors.
Then, once this is installed what type of mcb is required, i calculated 41 amps for this shower, is that right?, if so will it be a 45amp mcb?
Any help would be great!
