fiat marea cam belt slack
14 Oct 2007
Lancashire
hi got a fiat marea 2ltr problem is the cam belt has gone slack and the engine will not start. on inspection it looks like the tentioner has slipped.
can anyone tell me whats the best way to sort it out. ie. finding tdc and or if it will requirer a new cam belt.
cheers
I wouldn't continue trying to start it. Best to remove the covers and belt, to inspect the belt for damage. If it's damaged, i.e. teeth missing, replace it and try turning the engine over by hand before using the key.
Hi Bez
Sorry to say but it's about 90% sure you will have engine damage. You will need 2 special tools to lock the cam shaft. Also a dial gauge plus an adapter to set the timing. I think you should get a Haynes Manual first, read up on it, then decide what to do.
:cry:
