FIAT PUNTO STARTING PROBLEM
14 Nov 2005
West Midlands
I also have a problem starting the car in the morning. It sounds like the battery is flat, but I have had the battery tested at a couple of places and they say the battery is fine but it is just flat, something is obviously causing the battery to go flat overnight. The car has a good run during the day as I am travelling about 40 miles every day.
COULD ANYONE PLEASE PLEASE HELP.
could simply be a bad earth connection from battery to body of car........Italian steel/electrics not known for longevity :cry:
Then do the obvious.Disconnect the battery overnight,if it starts in the morning you will have to find what is draining the battery by using a suitable Amp Meter in line with the battery + and pulling fuses to find the drain.
