I'm seriously considering going the fibre cement board instead of timber for a small part-clad garden room (approx 15m^2 of cladding) on a 5x3m room (thanks to suggestions in a previous thread).
I've never worked with this material though I do have some samples, I have no 'feel' for how it behaves. I'd welcome any tips or experiences you've had but I do have a few specific questions:
- Cutting. I have a Dewalt 18V battery 184mm circular saw and I am ordering a mitre saw (leaning towards the Evolution with the multi-blade) can either of these be used with a special blade, or do I need a dedicated "wet saw". I see Screwfix have dedicated fibre cement blades but the 184mm one is £60 and listed as "coarse cut". If the Evolution mitre multi-material blades would work then that would be great!
- The ones I'm looking at now (CladCo) their installation guide says I should install a DPC/water-proof strip outside the battening between the cladding board and battens, particularly at corners and joins. This is separate to your breather membrane under the battens. I've been spending quite a bit of time looking into timber cladding and never seen this, the whole point is that water can get through but the air-gap provides drainage/ventilation. Not sure if this is different for cement boards or the manufacturer is just being extra cautious?
