Fibre cement slates as DPC/packers
11 Jan 2013
Durham
Morning all,
Are fibre cement slates any use at all for using (in a brick wall) as a DPC or for packing up lintels etc? (I've got a fair few skinny offcuts from my reroofing job, would be nice to find a use for them)
Cheers
I'm not sure if this is a serious post but i'll take it at face value.
Never use fibre cement slates as packers for well almost anything, and especially not for load bearing use below lintels or joists etc.
Ta- thought that would be the case but reckoned it was worth an ask. Landfill it is then :)
Crack on we've been using them as packers for years. They are produced under immense pressure and have a high compressive strength.
I live and learn. And I learn from others experience but its still not something that i would do myself, although i'm sure that you've used them safely with no after affects.
I've never seen it done, have SE's seen and passed the practice?
I didn't know about the compressive strength but what about tensile capacity esp. for example, in joist pockets where there is always a little joist spring with any given load?
FWIW: I dont have the reference but there was a well publicised commercial building collapse in outer London some years ago where the major cause was a lintel packed off a padstone with layers of some (non-specified) very hard material that eventually crumbled due to water ingress and traffic vibration.
Is this what you were thinking of? :LOL:
