Fibre cement tiles
22 Nov 2009
Oldham
Can anyone help with a source for these? 200mm wide so I guess x 400mm height.
Second question, the lead flashing, just visible in the first image, will be replaced by leadax - if I didn't replace the tiles at the moment would I be able to "lift up" the leadax to do them later?
TIA.
No felt to be seen coming over the fascia and the gutter - but if what you have works, & you intend to replace like for like then leave fresh/new felt and/or plastic eaves tray alone, & batten setting out as it is.
Leadax can be manipulated - but the lead looks fine, why change it for leadax?
Why not email Eternit with your pics and dimension question? But first slide out the broken slate and accurately measure it - dont guess be certain.
I've assumed asbestos so will take precautions. Lead is split every 2 foot or so. Definitely 200mm wide, the main roof are standard 600x300 but they've used smaller ones on the canopy. I'll try a few suppliers then look into cutting down.
