I'm changing the fuel pump on a Mk IV Fiesta.
I'm struggling to remove the fuel lines from the pump connectors (colour coded red and white). I've tried squeezing the plastic tabs on the sides, but can't get the line fitting to release.
Now I've managed to snap off one of the tabs, so things have gone from bad to worse.
Has anyone any ideas for how to disconnect these fittings (especially the one I've damaged)?
The Haynes manual simply says: "release the protruding locking lugs on each union, by squeezing them together and carefully pulling the coupling apart". This worked fine for the connectors to the filter, but the pump connectors seem to have a different design.
