I have a traditional central heating system that heats the radiators and also a hot water cylinder.
I went in the loft recently and noticed quite a bit of condensation.
I switched the central heating on and noticed that the vent pipe into the feed/expansion tank (the end of it is below the water level) is as hot as the radiators and the water in the feed/expansion tank is steaming hence the condensation.
It seems to be plumbed correctly looking at the diagrams I have found online.
The vent and feed pipes are tee'd next to each other on the pipe between the boiler outlet and circulating pump inlet.
Should the vent pipe be below the water level?
Any other ideas what the issue might be please?
Thanks.
Thanks.
