Fill level
16 Apr 2006
I have a Whirlpool \\\"Ultimate Care II\\\" washer that only fills to the small capacity volume. I have cycled the switch many times and it seems to function fine but there seems to be something malfunctioning with the level sensor.
the water level pressure sensor is located on the top you can recoginse it by small pipe is connected. you can alter the level of water allowed by screwdriver there is three plastic screw on the top level pressure sensor you only need the on in the middle.
