Just bought a house.... and posting my first question to this forum!
I will sand the floorboards (traditional/basic pine) of my living room/dining room.
As is always the case, there are 2-5mm gaps between the floorboards. I wonder if - for insulation reason - it is possible to fill these gaps. And if so, what should i use?
I thought that I should first sand down the floor boards (I will hire a floor sander) once, possible use the sawdust + mix it with a sealant (of which sort?), insert it, let it dry and then do the last sanding.
Is that sensible - what experience is out there??
M thanks
M thanks
