fill valve nut spanner
24 Jul 2006
South Glamorgan
is there a dual open spanner for the locking nut and flexit hose connector for cistern fill valve, space for access is very tight, tried an adjustable its to long, what id like ideally is a thin dual open spanner that will fit either nut, i was going to diy box spanners with a grind out.
If you have the type of close coupled WC where access to the inlet valve securing nut (usually white plastic) is though a hole in the pan, the only realistic way of removing the inlet valve is to separate the pan from the cistern. If doing so, renew the doughnut washer and close coupling bolts / close coupling kit at the same time.
yea iv thought of that, bit of a pulava as there are three panels above pan, bottom panel to get at the doughnet washer has to be removed, and its a real pain the the proverbial, its supposed to lift off, but it don't and i cannot get my in to see what blocking the bugger, who ever desigend the wc needs there head felt, if remove middle panel, cistern is ever so slightly lower then panel wall...again trying to see, like doing it blind with fingers for eyeballs..
Photograph(s) would be useful. General view and inlet valve securing nut.
