I've put up a new wall that is at about a 20 degree angle to the wall next to it. Because of the angle I can't fix the end of the plasterboard to the frame. Instead, the plasterboard overhangs the frame by about 10cm (the 10cm area havng a triangular gap behind it.)
When i press against this 10cm end of the plasterboard there is some movement. I'm therfore worried that if I get the wall skimmed it will crack if this happens. What I'm basically looking for is a way to fill the triangular gap behind the 10 cm overhang of plasterboard. Could I use one on those 'no more gaps' expanding fillers?
