Filler loop valve causing lack of hot water?
2 Apr 2017
We just had our annual boiler inspection (unvented cylinder), and we mentioned to the bloke that we've had an ongoing issue with the CH working normally, but no hot water through the taps unless we run the immersion.
He had a look, did a test that involved a loud noise in the pipework (I wasn't at home at the time, so didn't see what he did, I'm just going by what I was told), and said that the problem wasn't with any of the zone valves (as I'd thought), it was with the filler loop.
Could a faulty filler loop cause that problem - CH working normally, but no hot water? I don't have any reason to doubt him, but I wasn't at home to ask questions about exactly why the filler loop would be the culprit. Just trying to understand how the hot water works!
Boiler is Worcester 14/19 CBi, cylinder is this one:
Get a different engineer.
Your cylinder also needs attention looking at the picture. Although, depending on how long that red light has been on, it might be too late.
That's an old photo, and the red light isn't actually on.
And he was just the guy come to do the annual safety inspection. He wasn't an engineer called in to diagnose the problem.
If you set the hot water to come on, does the zone valve open, and the pipe the other side of it get hot.
He had a look, did a test that involved a loud noise in the pipework (I wasn't at home at the time, so didn't see what he did, I'm just going by what I was told), !
That'll be the Hammer Test - what we used to do when changing the old ballvalves in roof cisterns. Such a quick job that it was best to sit in the loft for 15 minutes tapping the pipes :sneaky:
But the hammer test just checks the pump is stuck, and the central heating was working, so this bloke - who's supposed to be making sure the unveted cylinders okay - doesn't seem to know what he's doing. Or am I missing something. Is there another hammer test by any chance.
Is the cylinder higher than any of the radiators? Are the radiators upstairs warm at the top too? What is the pressure guage on the boiler saying?
Maybe the system needs topping up and he can't due to a faulty filling loop, and the cylinder is higher than the head of water. Sounds pretty far fetched, but it's the best I can do.
