Filling a gap between kitchen worktop and the wall
22 Sep 2008
London
Hi all,
I've recently had some new kitchen worktops fitted and I'm soon to start tiling the surrounding walls. However, behind one of the worktops, there is a gap of about 15mm at its widest between the edge of the worktop and the wall, which runs for a metre or so. I want to fill this so that when I come to tile, I have something to rest the tiles on and also does even up squirting a load of sealant behind the units.
I thought about using expanding foam filler for this, but the gap is behind my new gas hob and above my oven. As the foam is highly flammable, I think that might be a bad option!
Does anyone have any ideas what I could use instead of foam? Would standard gap filler (acrylic) be applicable, or would it be too big a gap to span?
Suggestions welcome!
Fire rated foam is available.
However, I would cut a fillet of wood to fill this gap, which would meet your need of something to rest the bottom row of tiles on. You could finish with a silicone bead, or use a worktop sealing strip.
Does this gap extend above the work top? if so, when you tile across this area it will probably look like a sow's ear. If this is to be the case and you are going to use tiles, a good option would be to get some one coat plaster and make the wall above the worktop straight and flat then tile back down to the worktop. Sorted. :)
