Apologies if this should be in a different forum, but I am ultimately going to be tiling this area.
I have ripped out our downstairs cloakroom to decorate, tile the floor and put in a new suite. Unfortunately as I was trying to remove the toilet, the screws fixing it to the floor had been covered with something that looked like cement and needed to be drilled out of the screwholes, after a good hour or so of trying to drill out the screws with no luck we ended up just taking a crowbar to it to lever it off the floor which has taken a chunk of floor with it as shown in the picture. The cloakroom is on the ground floor, I think the floor is cement. The black tile-looking things in the picture are actually the sticky black stuff that was fixing the original vinyl floor tiles which where under the carpet.
The crater is a bit smaller than the size of a toilet base and upto 5mm at its deepest.
I was wondering what would be the easiest material to fill this with? I am going to be laying 9mm thick floor tiles and then there will be a toilet in the same position.
Would cement be ok?
Thanks in advance
Richard
Would cement be ok?
Thanks in advance
Richard
