Filling behind skirting
12 Nov 2012
Avon
Hi all - first post!
I've just put a load of pine skirting up on the walls and my wife would like it to be stained/varnished - which isn't too much of a problem in itself.
The problem is how to fill the gaps at the back - the plasterers left me with wobbly walls and although I've screwed the skirting onto the wall, I wasn't able to close up all of the gaps!
In a different room, I used white decorator's caulk to fill these, and because that was white MDF skirting to be repainted, that worked a treat. But in this current room, I'm not sure what the best choice is.
The walls aren't quite white so any caulk would need to be finely repainted to blend these in (agonisingly difficult in some places). The alternative would be to somehow use a filler that could be blended in with the stain, but I'm worried that this isn't possible or would be a bit naff.
I'd kept a load of the sawdust from the chopping/scribing thinking I might be able to mix it into the caulk to give a stainable surface, but I don't know if it will work/would just look like a bodge!
Can anyone offer any advice on what you would do?
Cheers,
Fred
flooring mastics are available in a wide range of colours to match the wood but you would still need to do some cutting in.
Alternatively fill with red devil onetime filler and try to stain it. most other lightweight fillers are crap.
