Can this be plastered straight onto brick/plastic Conduit or does it need a render first, if so what is the mix ratio.
I have a new SDS drill and it was a bit of a learning curve (even on half power the wall was like butter, surprised me a little) ended up with a crack which I attempted to widen for filling but the big chunk was clearly loose so I though best to remove.
If plaster will do is it just patching plaster and finishing plaster to skim? Do I need a coat of PVA over wall and conduit (read that somewhere?)
thanks for the help and advice
The upper part was done after the errors of the horizontal cut, I used my weaker drill to guide the chase, drilling several holes and seemed far better that way....
https://drive.google.com/file/d/1jsPYFnDjfLsIs-XTLB2FvRzYtNkhxO2m/view?usp=sharing
After chunk Removed
https://drive.google.com/file/d/1yeA6n_EwxidB9xsyo5xjzSgXHCxMKVfE/view?usp=sharing
https://drive.google.com/file/d/1cnOGI04MTu8QstrttQ2OfLRjII2FUlot/view?usp=sharing
After chunk Removed
