Filling gap between kitchen cabinets.
21 Jun 2009
Aberdeenshire
Afternoon folks,
Currently looking at refitting my kitchen (2600mm wide x 5000mm length).
The oven is to be a straight swap (in middle of the 2600mm wall) but the corner units I'm looking to get are 900mm each. Add in the normal 600mm integrated oven cabinet, I'm looking at a 100mm gap at each side of the oven.
I have pondered if it would be simple (I will be getting a joiner to fit the kitchen) for a joiner to 'improvise' a filler for these gaps if I was to supply a suitable length of wood (matching the cabinet doors).
Thanks in advance for any help.
Infills are easy enough to do you could get an extra base end panel, which the joiner could use. Have you got a plan for the kitchen though? As corner units do not usually go fully to the wall to allow them to line up correctly with the return units.
Hi.
By return cabinets, am I right in thinking you mean the ones running at right angles to them?
In this case, the corner unit are actually L shaped (900mm both ways) so the adjoining cabinet just follows on rather than having to match up with the corner units' door.
Hope this makes sense!
