Hi All.
Long time lurker, but finally registered to post and contribute as I'm always on here checking stuff out.
So, I have an inexplicable and annoying un-paved patch in my driveway, roughly half a square metre (essentially it's a patch of mud in front of the front door at the moment...)
It's bog standard block paving brindle surface, and I have bought enough new blocks to fill the gap. It also has edging all round the patch, so it doesn't need anything like that adding. My question is regarding laying it, and what to put under it really, as it's such a small job.
I have read various things about using a membrane first, then hardcore, then sand (not sure what type) and compacting between layers every 100mm or so. Finally finishing by brushing silver sand into the gaps. Because it's just a small patch I was intending to compact it by hand with a sledgehammer or something similar, and then tapping in the blocks with a rubber mallet.
Any advice on a). How deep I need to dig out first, and b). if the above recipe sounds like it should work?! I'm really only looking for the simplest and cheapest way to sort it!
Cheers all!
Cheers all!
