Hi all,
When installing a filling loop, I understand that the double check valve / isolator valve end of the loop should go on the mains supply side, and the isolator valve should be on the CH side. Please correct me if I'm wrong.
Now the isolating ball valve (without the check valve) has an arrow on it to indicate direction of flow (from mains supply to CH), but this assumes that the pressure at the base of the arrow is higher than the pressure at the tip, which is the case when the filling loop is in use.
But when the flexi-hose is disconnected, the pressure at the tip of the arrow is >1.5 bar greater than at the base of the arrow.
Does this not risk the isolating valve leaking, since the CH pressure is pushing the ball valve in the 'wrong' direction, back against the spring clip?
Thanks in advance.
Thanks in advance.
