Depending on where your filling loop is, you will more than likely need to drain, or partially drain your heating system. Once this is done, turn off the mains feed to your house, make sure the loop is in the closed position, open the lowest cold mains tap to drain the cold water down, and carefully remove the loop. If some water comes out (and it more than likely will) try and get a container to catch the water in. Then fit your new loop ( there are a couple of variants, try and get one to match your original), making sure its fitted the correct way round ( there should be an arrow marking ). Then refill your system. The instructions I've issued are bearing in mind that you know how to drain your heating system properly, and refill it as well. Don't forget to add some inhibitor while you have the system drained, adding it when you refill. Hope this helps you. If you are still not confident in doing this, find someone who is
The OP said that he tried opening the valve, so it might not be just the isolator, may be the non return valve sticking as well. If the OP is going to be dismantling a part of the CH system, it may be advisable, unless he/she wants water spillage, to drain, or partially drain the system. If they called a plumber in, the plumber could probably solve the issue in next to no time. As it sounds like the OP is a DIYer then perhaps its better drain the system to save any mess, then have a look at the whole loop
