I want to replace a timber sash (single-glazed) with a double-glazed unit and new uPVC frame.
The dimensions are 1000mm wide and 1700mm in height. Due to it's proximity to the floor, it'll need to be safety laminate glass.
I am considering the possibility of installing one solid pane of glass, hinged along the vertical. I expect this will require a heavy duty hinge.
It's on the ground floor (living room) looking into a back yard which gets no direct sunlight. I realise with no vertical bar this can make a window look somewhat characterless from the outside, but the window won't be seen by anyone due to its location. Also this would let in maximum light.
Can anyone foresee any issues with this? That is, given the size/weight of the laminate glass window, and with it being just one glass unit. Thanks!
