filling screw holes in tiles
28 Mar 2011
Conwy
Hi All
Seeking brilliant ideas for filling in screw holes in white bathroom tiles after an old shower was removed, the new one having to be fitted in a slightly different position due to the pipe entry points in the shower unit.
My usual method of using white silicone hasn't done the job, and a bit of browsing has pointed towards using P38 body filler, flattening then sanding and applying white paint. I did think maybe there were caps you could buy to fill in screw holes, but nobody is suggesting these as an option so maybe they wouldn't look so good.
There's the option of sticking transfers on the damaged tiles, but they could easily look rubbish. The existing tiles are 150mm square and have a dimpled surface and a slightly off white finish, so I can't swap them for bog standard flat white tiles. They were bought from Focus DIY which no longer exists.
Any other constructive ideas for filling these holes welcome, thanks.
That’s a possibility, yes. Might have some ancient fix n grout in my rotting shed.
I would go for the screw caps.
Unless you could put some hooks on the wall - for shower cap, soap, whatever, whatever...
Thanks both for your additional suggestions.
I put grout in the holes last night, and it looked OK under artificial light. Once I've seen the results in daylight I'll decide whether I need to try something else.
