I am planning to insulate the subfloor in my bungalow.
Lift laminate
Lift floor boards
Not sure on joist depth but I will insulate this amount with either celotex or mineral wool, leaving the void below free for air flow.
Replace/refit floorboards
Replace laminate
Obviously the main bit of work here is lifting the floor boards.
A company - www.thermabead.co.uk
Have suggested that their method will not require the floorboards removing, instead they will drill and fill with thermal beads (similar to cavity wall insulation)
My concern which I raised with them was reference the air flow. I was told that as the beads would fill the entire void then there would be no no issue with rot etc.
What are everyone’s opinions on this?
Lift laminate
Lift floor boards
Replace laminate
