Filling the gap under valley edge tiles
30 Jul 2009
West Lothian
The tiles that border our valley gutters have a sizeable gap under them. They are not mortared.
There's enough space in there for birds to nest, which is not ideal, so I want to fill the gap with mortar.
Is it OK to first put some expanding foam in there as a backing? Otherwise it's going to take a lot of time and materials to fill, and I know from (limited) experience that the mortar will tend to slump out unless it has something to fix against.
Expanding foam may lift the tiles up, block it out with a stiff mortar mix and finish it the next day.
Mortar isn't really used in valleys in Scotland anymore.
Your best bet is removing the tiles and installing comb-fillers - https://www.roofingsuperstore.co.uk/product/marley-eternit-eaves-comb-filler-62mm-x-1000mm.html - (You can get cheaper ones than this)
Thanks. If I used something like leadmate could I basically stick those to the valley? Otherwise I guess it means removing a couple of tiles on each side for the full length of the valleys (there are four) and nailing these onto the battens. Which ends up being a fair bit of work, but maybe that's what's needed.
