I have previously isolated the feed to the header tank in the past when working on the system, rather than isolating it in the header tank itself. I just noticed after draining some water via the magnetic cleaner that the feed makes an almighty foghorn noise. The vibration is fairly extreme to the point where the isolation valve appears wet afterwards.
My plan has been to switch off the boiler and then isolate the feed itself. In this case I wanted to reassure myself that the header feed was indeed the header feed so after a couple of jugs of dirty system water, I turned the isolation valve back on and the foghorn began. It continued for about 10 seconds before tapering off.
I'm about to do a lot of work on the system and wondered if this isolation valve is a point of failure, or even whether I'm doing this right?
