No, the only way is to embed bits of rebar in the first bit that stick through your formwork. When the first bit has gone off hard (3days+?). Remove the formwork, wire brush the new concrete face to expose the aggregate, give it a spray of water and then pour next mix. You hope that your second mix will adhere to the rebar and face of the older concrete.
What is going into this hut ?, you seem to be building the foundations for a two storey brick built house with a slate roof. The shed I built in my last house was on a sloping site, about 12" drop along its 12' length. I dug through the top soil into the clay subsoil, 6"?, layed a 6" wide strip foundation. On this I built a single skin brick wall , four bricks high at one end and one at the other. Put the dirt into the big hole. Put a screed on top of the earth and just overlapped the brick tops. I had a 1000kg milling machine on this along with a 5 cwt lathe and loads of metal.
Your foundations are meant to become part of a stable earth layer, so tossing blocks into a trench will not do it, unless you put down a layer of bedding mortar first. So are you down to a stable layer of soil? , even colour, even texture when whacking it with a hammer equal load carrying ability?
Is the locality flat (its not going to slide downhill?).
If the answer to all of these questions are yes then I would use the mixer to make up some mortar, shovel in to the trench smooth it off with a spade, drop your blocks on, and thump them down with a big hammer. Repeat next course overlapping the first, so you are crudely building a wall in the bottom of the trench. Don't get to neurotic about the squareness, because when you have come up to just below ground level, you can then move to concrete and your formwork. Because you trench is so wide and deep you will have to back fill and thump down earth on the inside of the blockwork if your cement has not filled the cavity.
It is very unlikely that the top surface will be flat enough to carry floor joists without some more fiddling around with mortar and a DPC.
Frank
