Hello all. Feature wallpaper (choc brown!) has shrunk a little - exposing light wall behind. Gaps are max 1mm. Any help on 'what product' to hide these seam gaps with - along with a 'how to do' much appreciated. Thanks John
thanks dazb - the problem i forsee is that the gap is so small - would a felt tip (for example) just run over the top of the gap - rather than get in the joint? Thanks for your input.
