A little while back the wife and I bought our first house and set about making it a home as detailed in the link. //www.diynot.com/forums/viewtopic.php?t=203825&start=0
With a functioning if somewhat ghastly bathroom we decided to spend our time and money working on the rest of the house and so our budget was spent. Finally we have the money available to do the bathroom and so that's what I'll be covering in here.
As you can see it's in need of a little modernisation!
Thus far everything (including tools) has been supplied by TradingDepot, PlumbWorld, Screwfix, ToolStation, MachineMart, Tradetiler, TileBase, CarpetRight & good old ebay.
Everything is sitting at home ready for work to begin, I have already removed all of that particularly catching wooden panelling from the walls and ceiling as well as as many tiles as I could easily without removing the cistern, sink and those immediately around the bath.
Walls are in good condition with what appears to be a cement render behind the tiles and standard render and skim under the wooden panelling.
We'll be ditching the old electric shower which was limited to just 7.5kw because of the cabling and replacing with a Trevi Boost. The walls are going to be 16x10" tiles floor to ceiling with a 24x3" border at window ledge level. Flooring will be vinyl because I refused to tile or lay laminate on a suspended floor!
We are also turning the bath around because we wanted a bath screen which is not possible with the bath in its current orientation. This is because the bath is 700mm wide and the window is only 640mm from the wall. The shower screen would have nothing to support it!
I'd class myself as a solidly competent DIYer. I am confident in my ability to pick things up that I have not done previously and I have done or helped out on a lot of DIY in my 26 years. That's included installing 3 kitchens including proper joints in the worktop, some wiring where allowed, a little plumbing, painting, tiling, laying laminate and insulating and boarding the loft. I do however know my limits so will not attempt things unless confident that I can produce a solid result.
More pics and details as I go!
