Finding a central heating leak causing pressure loss at boiler
13 Jan 2008
Nottinghamshire
Having recently spent hours looking for a tiny leak in our Combi based pressurised central heating system, I thought I would pass on this tip for anyone else experiencing pressure losses.
For less than £6 on eBay you can buy a moisture (damp) meter which can be pushed into carpets around pipes and display the percentage moisture present.
In our case there was a tiny leak from the back of a joint fitted to the hall radiator. Water was dripping occasionally, passing through the carpet into the underlay leaving no mark or stain whatsoever on the carpet. The damp meter displayed 43% moisture all around the offending pipe when pushed through the carpet into the underlay! The readings everywhere else in the house are between 0 and 5%.
I didn't actually buy the meter for this purpose but it proved invaluable in tracing the leak!
