I have a Ferroli 25c boiler that is losing pressure. It is fine when heating is on and loses fairly quickly when cold. I assume this is a leak that stops when hot and therefore pipes are expanded. The pipes are under concrete / tiled floors so how can I find it. Someone suggested leak sealer but as it works on contact with air, it probably won't harden under concrete. I have been told that I need to get someone out with thermal imaging equipment to find the leak but as it doesn't seem to leak when hot I can't see how this will work. There is no sign anywhere of water coming through the concrete. Any ideas on how to find this please without digging up the whole house!!
