Finding a Square (Pyramid) Oak cover for 22mm pipe for Laminate Floor
16 Nov 2013
Kent
Does anyone know of a place that sells a square cover for the expansion gap around a 22mm pipe?
I am planning to lay oak laminate flooring but need to find a cover for an expansion gap around a 22mm (gas) pipe that is almost touching the skirting board.
I don't want to remove the skirting (and it would be really difficult around that gas pipe as the pipe comes so close to the skirting board from the floor and then goes through the wall just above the skirting board) and was planning to use scotia.
To make it look tidy around the pipe I think it would be best to use a square cover, that I trim down to accomodate the skirting, and then run scotia on both sides.
However, I can't find any square covers for 22mm pipes (for 15mm pipes I found this http://www.creative-wood-floors.co....-pipe-covers-rad-rings-collars-for-15mm-pipe/ but I am after somehting similiar in the right size)
How are your woodworking skills? Looks simple to make (in two halves, of course).
Well, I fitted our kitchen and laid mutliple laminate floors. But I haven't done any 'general' woodworking or crafting.
I do have a circular plunge saw with a track for bevel cuts and I am sure I could find a 22mm drill bit.
But where would I find a nice but small piece of oak?
I just had the idea to order some (free) real wood flooring samples. If they are large enough, I might be able to make something, maybe...
Our main timber merchant sells solid hardwood lippings for door resizing. these are circa 7ft long, planed all round, and come in to us at about 48 x 10mm or 55 x 10mm (for 44 and 50mm doors respectively). They are normally some non-descript far eastern hardwood (for painted doors) although sapele mahogany and oak are available as well.
