Folks
I am a lessee in a block of flats and act as director of the block's landlord company. The building is circa 1913, is brick with lime mortar and 6 inch reinforced concrete floors.
Two flats, on the 1st and 2nd floors, have 9 sq meter balconies one above the other. The upper balcony is supported on the lower balcony by walls on two sides and brick columns on the open sides. The balconies are quarry tiled with drain channels along their outer sides parallel with the coping. These drain thru' cast iron pipes in the brickwork to a vertical rainwater pipe.
The ground floor flat below the balconies has substantial damp over 2-3 sq metres on the inside of an external wall directly below the open side of the balconies, which has persisted for nearly 2 years. To fix the damp we commissioned a surveyor to inspect, generate a schedule of work and to supervise a contract to fix the damp. The contract repaired rain water goods & repointing but the damp persisted. We called back the surveyors who pottered about and produced another report basically stating they couldn't find the cause and that we should commission a further investigation from them. Later we made more repairs to a rain water pipe spur passing thru' brickwork. We have 3 times called to site a pipework/drains specialist to check the rainwater goods inc. pipe spurs and the ground level gulley and I am personally satisfied that all rainwater goods including the pipe spurs are now watertight and that water is not backing up the downpipe.
We recently brought new surveyors to site but after nearly 2 hours of damp measurements/inspection they expressed no firm opinion as to cause and suggest that the wall be left to dry out and be reinspected at the end of summer.
Presently we are ~13K down, with an angry gnd floor lessee and no solution. I believe (and our builder) that the problem is water getting into brickwork between the upper balcony tiles and cracks in its drain channel, passing down the central brick column and into the gnd floor flat. A good downpour might provide the evidence needed to convince the surveyor of this but in case we have a dry summer I need to take further steps now.
So I have two questions:
1. Can someone recommend a firm that can perform tests to establish that water is getting into the brickwork (columns) from the balconies ?
Something along the lines of pouring water, perhaps with dye, onto the balconies and by taking damp meter measurements before and after soaking the balconies, are able to produce a report showing conclusively that water is passing between tiles and thru' drain channel cracks on the upper balcony into the central pillar, and into the external wall of the gnd floor flat.
The report must be able to determine whether we need to renew the tiles and drain channel of just the upper balcony or of both balconies
2. Can someone advise as to how the tiles should be removed ?.
A builder told me that if they are just "kangoed" up then debris could fill any cracks in the concrete making them difficult to spot. I have no reason to suspect the concrete, only the tiles and drain channel, but further work must be done correctly and, because of many past problems with surveyors, I don't feel I can just leave a schedule of further repairs to them.
You can find pics at: http://www.tfcta.homechoice.co.uk
