Fine cracks in walls (base paint)
9 Jun 2014
Yorkshire
I have seen you can buy a paint which fills fine cracks in walls.
I am redecorating a bedroom and have stripped all the walls, filled and cleaned them down. I have applied a water coat (emulsion and water) as my first paint layer.
The ceiling is the worst for cracks and so i have refilled again.
If i paint with my emulsions i imagine most cracks will go, but i was wondering if it was worth me using these special paints as a base coat before i properly decorate.
If it is recommended, what product would you recommend. The one i have seen is polycell smooth over.
For the best finish,have the walls/ceilings skimmed before painting.
Over the years have only use gypo eas-fill in well raked out cracks,then undiluted emulsion the filled areas first.Then when dry do all the wall/ceiling.
Paint to fill cracks,good luck there.
Not skimming as they don't need it. I can do it myself, but even so not needed.
I prob won't go for these special paints and just see how i get on with my first coat. I may need to fill again, but i think it might be ok.
