Finish or Multi
2 Mar 2009
Suffolk
Been asked if I could plaster a new Plasterboard wall. As I am still new to plastering, is their any noticable difference to the finish of 'Finishing Plaster' or am I OK just use Multifinish, also if I remember rightly I do not need to PVA the board first?
I only ever use Multi whatever the surface. A small advantage is Multi will give you a little more time which can be a bonus if you’re inexperienced. You wouldn’t normally PVA boards, just dust them down but, again, it won’t really do any harm; don’t plaster over dry PVA.
go for multi as rich says, as your still new to it the multi will take longer to go off so you wont struggle as much.
Multi for me every time, more time to play will it. If I remember right it's also cheaper than board finish, but not looked at board finish prices for a long time as I don't use it!
There is no need to PVA prime newly fitted plasterboard, if the paper is still bare.
Just tape joints and a double coat of multi, nice..............
Hi guys,
Sorry but what does PVA mean? Am new to this and want to learn about plastering.
Many thanks Paul.
