We have an electric towel rail installed on to a tiled wall. The water pipes entering the tiled wall are neatly finished and sealed with a flexible chrome "collar".
The electric cable to heat the towel rail when the heating is off, also enters the tiled wall, but is rather unfinished. The builder (for reasons not clear to me) drilled a similar sized hole as the water pipe holes, but says that he can't use a similar flexible collar because the diameter of the electric cable is too small for the flexible collar to be narrowed sufficiently.
Does anybody supply a smaller chrome collar which will work for electric cables?
