I've been busy boarding my bathroom renovation with Marmox Multiboards on the stud walls and Q-Boards on the external wall, which have gone on great but I'm now wondering what would be the best option for the Geberit Bog Frame ?
I can get away with a thickness of either 18mm or 20mm so I've got the option of either using some 12mm Marine Ply that I've got kicking around, topped-off with some 6mm Marmox fixed with tile adhesive I have left over (this would have to be taped as I'd have to do it in two pieces coz of the sizes I have left) or getting another sheet of the 20mm Q-Board and doing it in one piece.
Is the 20mm board really going to be up to the job of handling the forces of someone sat on the loo (will be tiled first before re-fitting the pan) or is the 12mm Ply/backer board better ?
Your thoughts please - TIA.
Oops, forgot to add, the tiles are 600x300 10mm porcelain if that makes any difference !
