Hi
I know there have been many posts about this topic as woodburners become more and more popular but I am hoping that someone out there will have the answers I need as this is causing me a massive headache!
I have taken out the old back boiler and opened up the chimney breast to find that I have an arched opening. The house is early 1900's
I want to keep the arch and obtain a smooth finish that can be painted inside the opening and on the chimney breast but it seems that there is no hard and fast way of going about this.
I have researched many methods but still cant decide which would be the best way to go about it. Ultimately I only want to do the job once. So
1. Would a lime render (5:1:1) skimmed with Everbuild 'Purimachos' heat resistant plaster crack from the heat of the stove in the opening?
2. Sharp sand or plastering sand?
3. Would this work as well as some sort of fire board (Enviroboard or promat monolux)?
4. If I render the front of the chimney breast would this also have to be skimmed with a heat resistant plaster or could I just use multifinish?
The stove I intend to install is a Firefox 8 (8.4Kw) by the way.
