Insulating utility room which has a door with step down into the garage. Floor is concrete slab with a damp proof membrane.
Building reg's require a FD30 door into the garage.
Question is how do we deal with the "raw" edge of the new insulated floor in the doorway?
Seems completely pointless to fit a fire door if there's 50 mm of celotex and 18mm chipboard at the bottom of it?
At the moment the door opens into the utility, but we're changing it to open into the garage
We're already having a few issues because ,once we bring up the floor level the height of our opening will be too small for a standard door/frame, so we were planning on taking out a course of bricks above the door to give us 2032 mm height.
As the door will open into the garage, would stopping the insulation short of the edge of the step and fitting the fire door down to the original concrete floor (which would also eliminate the need to remove any bricks) be an acceptable solution? Aware that it might look strange, but if not then how would you make the edge of the floor fire proof?
